Questions about 19 inch rims
Old Aug 21, 2003
PeN8503's Avatar
PeN8503 is an unknown quantity at this point
Do they affect turning radius?
Would i have to make any adjustments if i put em on my car, meaning would they touch the top or anythin? Would i have to make adjustments just to make em fit?
I got stock suspension right now, if i got 19s could i lower my car? if so, how many inches? If i dropped, how many inches away would my tires be from touching the top?
thx
Old Aug 21, 2003
PeN8503's Avatar
also if i got 19s what tires should i get? i like the rims/tires on blackbullet's civic, thats tight man, what tire size do u have?
Old Aug 21, 2003
civicvtec1ps's Avatar
Search and Learn
run with 215/35/19. your car might rub if you have drop , depends on offset of rims. camber setting, tire size.
check out tire calculator
http://www.7thgencivic.com/modules.p...tor&file=index
Old Aug 21, 2003
blackbullet's Avatar
The Legend
Before I had bags, I had the Ground Controls. My car was dropped with no fender gap and I had no problems with rubbing. I have 215/35/19.
Old Aug 21, 2003
PeN8503's Avatar
what do you mean when u say no fender gap??
Old Aug 21, 2003
Search and Learn
Old Aug 21, 2003
PeN8503's Avatar
ohhh my bad, i thought u mean u took something out from the tire well
when u had 19s w/o bags, how many inches was it dropped?
Old Aug 21, 2003
Search and Learn
he dropped until his bodykit scrapes
for shows
Old Aug 23, 2003
TOOLOWCIVIC's Avatar
Trust me u wont have rubbing problems with 19s rubbing unless u went with 235-35 tires then u would rub. I've had 225-35 and didnt rub and I've also rode on 20s in the back and had no problems. If u go 20s u wont be able to turn all the way cus it will it and theres not a small enough tire to go with them plus I only know of one company that makes 4 lug 20s. Well anyways to answer ur question u wont have problems rubbing with 19s.
Old Aug 23, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
thats my car up there tucked on 19s......... way to represent paul!!!!! no troubles with 19s.. buy mine!!!!!!!
Old Aug 25, 2003
RoadRunner's Avatar
19's are super dope
JKWood
Jul 28, 2015 03:45 PM
fordover
Jul 11, 2015 09:10 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
