How to Re-Torque wheels?
Old Aug 17, 2003
DarrenA's Avatar
DarrenA is an unknown quantity at this point
Well I got my 18" Centerline RPM's installed yesterday. It's been about 100 miles and I'm ready to re-torque them down to spec but I was wondering, in my manual that came w/ my torque wrench it said not to torque fasteners that had already been tightened. So should I take them loose then re-torque them. That doesn't seem to make much sense. So should I just set it to 80 and go at it
Old Aug 18, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
I'm thinkin' the authors of your torque wrench manual weren't really imagining re-tightening new wheels to spec when they wrote that. You would probably be okay to listen to the wheel manufacturer instead
Old Aug 18, 2003
Green Civic's Avatar
If you set it to 80 and the wheels are at 80, then the torque wrench will make a noise. As long as you dont keep going, you are just "checking". If it didnt click, then keep going till it does. Then after doing all four wheels you will know that all of the wheels are tight. Thats what I did whell I got my RH evos.
siliconvalley
Sep 15, 2015 09:48 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
rainman15
Sep 6, 2015 11:10 AM
