Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
EPS Wiring and control
Old Mar 3, 2024
vpeppers's Avatar
vpeppers is an unknown quantity at this point
I am retrofitting a classic car with the EPS steering rack out of a 2008 Civic Hybrid. I have all of the pieces I need to connect it up. I have the wiring diagram. I need three things to complete my project:
1. ECU pinouts.
2. DEP connection (Tach test signal) voltage level.
3. The signal type and levels on the CANbus speed signal.
If anyone has this information, I sure would appreciate getting it.
Also, does anyone know the module identifier?
Old Mar 4, 2024
BrotatoChip's Avatar
Super Moderator
Re: EPS Wiring and control
I have a schematic for the EPS system, but I presume it's for the Si trim and not the Hybrid.
Old Mar 4, 2024
vpeppers's Avatar
i'll take whatever you have. how do I get it?
Old Mar 4, 2024
Super Moderator
See the below links. First is a bit easier to read but doesn't include terminal numbers. The second, you will have to zoom way in to see anything.
https://civic.hondafitjazz.com/A00/H...BAT00i021.HTML
https://civic.hondafitjazz.com/A00/H...000EAAT00.html
Old Mar 4, 2024
vpeppers's Avatar
Thanks. That helps.
bakablo
Oct 26, 2004 09:24 PM
RyzRocket02
Nov 1, 2002 03:53 PM
InanimateCarbonRod
Sep 16, 2002 01:34 PM
CoolMD
Apr 16, 2002 09:34 AM
civicpride
Feb 6, 2002 07:53 PM
