Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
2006 Honda Civic Hybrid Specifications
Old Feb 6, 2006
Stigs's Avatar
Stigs is an unknown quantity at this point
ENGINEERING: ENGINEERING
TRIM LEVEL HYBRID
Engine Type
In-Line 4-Cylinder
Engine Block/Cylinder Head
Aluminum-Alloy
Displacement (cc)
1339
Horsepower @ rpm (SAE net, Rev 8/04)*
110 @ 6000
Torque (lb.-ft. @ rpm)
123 @ 1000-2500
Redline (rpm)
6300
Bore and Stroke (mm)
73 x 80
Compression Ratio
10.8:1
Valve Train
8-Valve SOHC i-VTEC®
Multi-Point Fuel Injection
Standard
Drive-by-Wire Throttle System™
Standard
Front-Wheel Drive
Standard
CARB Emissions Rating
AT-PZEV
Direct Ignition System with Immobilizer
Standard
100,000-Miles-or-More Tune-Up Interval
Standard
ENGINEERING: ELECTRIC MOTOR / GENERATOR
TRIM LEVEL
HYBRID
Permanent Magnet Motor
Standard
Power Output
20 hp / 76 lb.-ft.
Motor Width (mm)
70
ENGINEERING: ELECTRIC POWER STORAGE
TRIM LEVEL
HYBRID
Nickel Metal Hydride (Ni-MH) Battery
Standard
Output (Volts)
158
Rated Capacity
5.5 Ah
ENGINEERING: TRANSMISSIONS
TRIM LEVEL
HYBRID
Continuously Variable Transmission (CVT)
Standard
ENGINEERING: BODY/SUSPENSION/CHASSIS
TRIM LEVEL
HYBRID
Unit-Body Construction
Standard
Control-Link MacPherson Strut Front Suspension
Standard
Reactive-Link Double Wishbone Rear Suspension
Standard
Stabilizer Bar (mm., front/rear)
24.2 / 12.0
Power-Assisted Rack-and-Pinion Steering
Electric
Steering Wheel Turns, Lock-to-Lock
2.71
Steering Ratio
13.52
Turning Diameter, Curb-to-Curb (ft.)
34.8
Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in., front/rear)
10.3 / 8.7
Wheels
15" Lightweight Alloy
All-Season Tires
P195 / 65 R15 89S
Compact Spare Tire
Standard
Old Feb 7, 2006
vtec12's Avatar
vtec12 is an unknown quantity at this point
Ie virtually nothing that differs it from a normal Civic other than the fact its hybrid.
Nice to know that the basics are still there so its not a complete alien to work on.
Old Mar 5, 2006
anteater's Avatar
anteater is an unknown quantity at this point
Power Output
20 hp / 76 lb.-ft.
Wow!
That's weak.. surely the driver is going to notice this sheer lack of power whilst driving?
I would never have thought it would be so un-powerful..
Old Apr 4, 2006
sizzler's Avatar
sizzler is an unknown quantity at this point
Yah but thats how you save money anteater.. less fuel consumption.
I dont think its too bad, you could still drive up hills well.
Its more of a city car anyway.
Old Sep 30, 2006
Flash!'s Avatar
Flash! is an unknown quantity at this point
Originally Posted by Stigs
Gas Engine Output = 110 hp @ 6,000 rpm
Electric Motor/Generator Output = 20 hp
Anteater - The 20 hp motor is the IMA Battery Assistance on TOP of the (huge) 110 hp Gas motor. Some specs list it as 110 hp TOTAL (including the battery assistance of 20 hp) and some list it separately but it is NOT just a 20 hp motor - that would be like a golf cart, silly. =)
Granted, when you happen to run out of gas and the car is only being propelled by the 20 hp motor it is instantly noticeable (don't ask me how I know). Nice to know that the car CAN limp to a gas station on battery power only with no fuel in the tank though. I didn't see that listed in the book anywhere but now I get to add it to the Appendix.
Old Oct 1, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
it is 110 combined with the IMA motor
jessicakaybby
Apr 20, 2015 12:11 PM
inarschenk
South
Apr 18, 2015 04:29 PM
dooner24
Apr 14, 2015 07:51 PM
