rediculous tire wear Honda Civic
I have a 2009 Civic, I took it for an oil change and warrenty check up and I was told the back tires needed to be replaced. I figured the mechanic was "out of it" as the car only has 30,000 km/20,000 miles. I looked at the tires and he was right they are almost bald especially around the outer edges. This is rediculous. I have owned Honda's/Acura's nothing like this has ever happened. There is obviously a problem with the alignment. I was also told this seems to be a trend for this car. Anyone else experience this problem on this forum.
Honda in Vic
Honda in Vic
Live for the Twisties
Re: rediculous tire wear Honda Civic
There's a TSB (technical service bulletin) on severe tire wear that was issued awhile ago, if you take the car to the dealership then they should replace your rear lower control arms free of charge and that will correct the problem.
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
