Air Conditioning Post issues with air conditioning here
Where exactly is the heater control valve?
Old Jan 24, 2020
AangAirbender's Avatar
AangAirbender is an unknown quantity at this point
I have a 2002 civic and have only cold air while at low speed.
i would like to check the heater control valve, can anyone tell me where EXACTLY it is? Pics can help even more.
Thanks
Old Jan 24, 2020
BrotatoChip's Avatar
Super Moderator
Re: Where exactly is the heater control valve?
It is on the firewall in the engine bay. Looks similar to this.
Old Jan 25, 2020
Is that it?
If yes, do I have to drain the coolant before take it out?
Old Jan 25, 2020
Ok actually I filled up the radiator then bled the system and now it works.
thanks.
Old Jan 27, 2020
Super Moderator
Yes that is the valve. Why was the radiator low? Coolant leak? Signs of head gasket failure?
Old Feb 1, 2020
Wankenstein's Avatar
Sounds like it had air pockets in the cooling system and now you bled them out. However, if the issue continues then (as bro-chip) is eluding to...it may be due to a head gasket breach.
bcbud3
Sep 15, 2019 06:37 AM
masmohs
Jul 22, 2018 03:25 PM
Jan 30, 2018 06:36 AM
tzoromski1
Nov 18, 2014 11:02 AM
LuLu12
Jun 23, 2011 08:56 PM
