AC problem that may be deeper
I have a 2003 Civic. It had overheated 3 times. Finally Replaced the engine with a fresh one. I notice after the last overheating session that the ac is not working. I have read many of these forums and no one has had the same exact problem as I have.
So here is what I know
Start the car A/C light is on in the dash.
when I remove the relays and measure for triggering signal coming to the fuse/relay box I am getting nothing.
since the horn is there we looked for the signal and found it and then attempted to locate signals for the compressor, fans etc
Can someone guide me to a step by step to locate this problem? All Fuses and Relays are tested.
does anyone have a diagram? HELP!! I have to get this car running asap. do not want to have an overheating problem again.
HOT FLORIDA SUN!
- Condenser fan(s) are not working
- Compressor Clutch, not engaging.
- freon levels are exact
- brand new compressor
- relays were tested with a power probe
- all fuses are good
- power probe is able to engage clutch and fans
HOT FLORIDA SUN!
Re: AC problem that may be deeper
Hook a advanced diagnostic computer up to your car and monitor to see if the PCM is attempting to send a signal to the AC relays.
If it is, backprobe the pin and see if it is working, if it is look for a break in the wire going to the relay.
If it’s not then your concerned with ac control switch and micu working correctly.
Put aside your thoughts this is caused by your over heating, it’s a A/C problem only.
At the ECM/PCM with the A/C enabled in the HVAC controls you should have ground at pin B6 (fan control, green wire) and E18 (compressor clutch, red wire).
It did yesterday, ran the self-test and had no problems. Now I have no lights coming on the temp control unit. at all checked all fuses. completely lost now. SMH
It is in the service manual which can be found here: https://www.civicforums.com/forums/1...pdated-10.html
There is symptom based troubleshooting in the service manual, page 21-68. Following the "A/C System does not come on (both fans and compressor)" it recommends checking the A/C pressure switch circuit, page 21-78.
What do you mean no light on the controller (backlight or A/C button)? Does the A/C button light come on when pressed? Does the mode, temperature, and fan controls work?
I GOT IT #14 under the dash.
ok i got the light back on in the temp control. ran a test and no errors.
relays under the hood are not clicking and the fans do not turn on when ac is pushed. now what?
update: found the pages you mentioned will try the step by step procedures
Do you have gauges for the high and low side? What do they read?
The A/C pressure switch is happy between 28-455 psi. If you're in that range the pressure switch may be bad. Follow the steps to test it.
ggoodwin
Interior
Jan 21, 2019 10:56 PM
2002CivicTDA
26
Jul 21, 2018 04:31 PM
BrotatoChip
19
Jun 28, 2012 05:11 PM
rescue46
Dec 13, 2011 12:33 PM
