High Idle On Hot Days on Slow Streets
Old Aug 23, 2023
Michael52's Avatar
Michael52 is an unknown quantity at this point
Smile High Idle On Hot Days on Slow Streets
97 Honda Civic Automatic.
155k miles
4Cl
On hot days over 90 degrees AND while driving the slow streets, the engine idles high after I have been driving it for a while. As it idles higher, the engine gets warmer and then starts to idle even higher (up to 3000 RPM) before I finally have to just shut the engine off and let it cool down.
Once it's cooled down a bit, I can start it back up and it idles just fine.
If I drive it on the highway on hot days, I don't have this issue. It's only on the slow streets AND on hot days. The cooler days don't cause any problems.
My mechanic has cleaned the IAC thoroughly, but that's about all we've tried.
The previous owner replaced the radiator himself, but I don't know enough about cars to verify his work.
Any suggestions are greatly appreciated.
-Michael
Old Aug 23, 2023
Colin42's Avatar
Re: High Idle On Hot Days on Slow Streets
Iac might need to be replaced, get an oem one
Old Aug 23, 2023
Michael52's Avatar
Thank you!!
Huntercav
Jun 14, 2017 05:11 PM
prr
May 5, 2017 10:15 PM
ravenator
Jan 21, 2016 09:22 PM
letricereed
Aug 14, 2014 09:25 PM
everymistake
17
Mar 5, 2012 08:13 PM
