Swamped in swap
Old Sep 21, 2020
Bravo1468's Avatar
Bravo1468 is an unknown quantity at this point
Swamped in swap
I swapped aB20 from a 00 crv into a 97 civic. I got fuel, spark and it cranks but wont turn on. Please help!
Old Sep 21, 2020
Wankenstein's Avatar
Re: Swamped in swap
Try starting with gas pedal to floor. If that doesn't work try it again using starter spray.
Old Sep 21, 2020
Colin42's Avatar
Re: Swamped in swap
Timing, compression?
Old Sep 22, 2020
Bravo1468's Avatar
Re: Swamped in swap
Timing belt was loose Temple tooth I replace timing belt and water pump now aligned my timing marks in the front but my distributor does not align with spark plug number one it points to number 2
Old Sep 22, 2020
Re: Swamped in swap
study firing order and correct plug wire positions on the dist cap
Old Sep 23, 2020
Bravo1468's Avatar
Re: Swamped in swap
If my intake camshaft spun around once will it throw my distributor mark off help I'm b20b
Old Sep 23, 2020
Colin42's Avatar
Re: Swamped in swap
There's timing marks on the cam and crank...
Old Sep 23, 2020
Bravo1468's Avatar
Re: Swamped in swap
Two cams on mark with crank yet my distributor is on #2!😳 I will post pics later on today. Its 100 degrees outside my house.
Old Sep 23, 2020
Re: Swamped in swap
was there an immobilizer for the 2000 CRVs? Genuinely curious, bc that would cause a lack of start
edit: that is, of course, assuming you went with the matching ECU
Old Sep 23, 2020
Bravo1468's Avatar
Re: Swamped in swap
Not that im aware of. I do have an ecu for the b20 from a 00 crv. My timing belt was loose. I replaced it with water pump. My timing marks align in front but dist is on #2. Maybe cam spun while belt was loose. Do i simply spin cam till dist. & timing mark align?
Cdever
Nov 3, 2015 07:12 PM
slammed 97 ek
Apr 1, 2013 03:31 AM
hooper95
Sep 12, 2012 09:42 PM
White0nGold
Engine Swaps
20
Jul 23, 2006 07:31 PM
