General Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
2000 civic ex
Old Jul 9, 2020
Daninthesand's Avatar
Daninthesand is an unknown quantity at this point
2000 civic ex
I have a 2000 Civic ex Manuel trans with 230k miles and still going strong! It's my daily work horse! Looking to replace the rear suspension. What would you recommend for closest to OEM but also for longevity. Not trying to spend a fortune.
I also have a pulsating idle issue after I installed a cold air intake. It's way worse at cold then running temp. It has a pulse of 750rpm. All vacuum lines are hooked up and accounted for. This also caused my gas pedal to be super sensitive.
If anybody is looking to get rid of any OEM parts I'm happy to take them!!
Old Jul 9, 2020
Colin42's Avatar
Re: 2000 civic ex
Kyb is the closest to OEM for aftermarket suspension. Beck Arnley is good too.
try cleaning the idle air control valve and see if that helps. Also make sure the intake tube is all sealed
Old Jul 9, 2020
Re: 2000 civic ex
Cleaning the idle control valve was the first thing I did. Did not solve the issue. This has been an issue for over 8 months. I've had multiple people look at it as well. Invested about $600 in parts trying to fix it. Everything is sealed. Have pretty much given up on trying to resolve the issue.
Old Jul 9, 2020
Colin42's Avatar
Re: 2000 civic ex
Does it go away if you put the stock stuff back on?
WKD DRGN
Dec 14, 2011 07:29 PM
iced_inferno
Jun 28, 2010 05:28 PM
mentee
Jun 27, 2009 11:56 PM
bmwe46m3
Jun 8, 2009 11:11 PM
imported_skip
Jun 7, 2007 08:55 AM
