Vss bolt size
Vss bolt size
My speedometer odometer and trip mileage wasnt working so I had the assumption the vss wasnt working, I made sure the wire from the vss had continuity all the way to the dash and it does, when I got the new vss today i went to take the bolt out and it was snapped, how long is it? I know its 8mm x 1.25 and a 10mm head but I cant find the length anywhere
1998 honda civic ex coupe
Re: Vss bolt size
Auto or manual? I'm assuming you're talking about the bolt that holds the speed sensor to the trans. For the auto trans it looks like an 8 mm bolt 30 mm long. If it's a manual it's a 6 mm bolt 25 mm long.
