Rear Disc Brakes and 4 to 5 lug Swap Post information on Converting rear brakes to disc and 4 to 5 lug here
Drums--->Discs SPELLED OUT
Old Jun 19, 2007
  #151
em2k3's Avatar
em2k3 is an unknown quantity at this point
Re: Drums--->Discs SPELLED OUT
Originally Posted by 95speedT
ya i know about it being 7th gen but i couldn't find anything on eg's. i believe some of the hatches from my gen had rear discs
you might wanna check on honda-tech.com. i believe the 95 ex and si came with a disc brake option, if not you can also use the integera set up.
Old Jun 19, 2007
  #152
cgomes's Avatar
cgomes is on a distinguished road
question, already searched.
prolly just missed it. but is there anything on how to do this for a 95'?
Heres a great DIY i stumbled on. Its for a 97 HB but the process shouldn't be too different.
http://www.diynetwork.com/diy/shows_..._40569,00.html
Old Jun 19, 2007
  #153
95speedT's Avatar
95speedT is an unknown quantity at this point
thanks. should work
Old Jun 28, 2007
  #154
RHCP0801's Avatar
signed up on ephatch, 5 mins later i found a rear swap for $220 shipped and here it is, installing it next sunday at my job
Old Jul 8, 2007
  #155
RHCP0801's Avatar
took me about 2 hours or so with air tools
Old Jul 10, 2007
  #156
cgomes's Avatar
Hey Guys After a month's worth of searching and prep work I just finished my swap last night. Guess what guys its on a DX (canadian). Works great. It responds quickly with minimal peddal effort grips like a gator. I'll post up pics when i get back from vacation.
Just wondering how people in general with the swap have found the Parking break performace. Basically i want to know if anyone has been able to lock the wheels with such small calipers? Oh i used acura El assembly, cables and break lines. Cheap NAPA blanks and cheap semi metal kevlar pads. Yes I am cheap, not only am i canadian i was born in portugal therefore i have cheap in my blood.
In summary I'm generally satisfied with the everyday driving although i wish i was able to lock them with the e break though. Price total $400cdn = $380
Old Jul 18, 2007
  #157
LT2004ever's Avatar
I wil fix vBPlaza today
so if we go rear disk swap we cannot pull up the parking brake?!
also guys where is sez "Everything else is just in reverse order. If you need to install brake lines on the discs, do it beforehand, make sure you use crushwashers with the new lines to prevent leaks."
when would you have to install new brake lines?? like if u were going stainless steel??
Old Jul 18, 2007
  #158
RHCP0801's Avatar
yes you can pull up the parking brake, you just need to use ep3 cables
instalingl the new lines before putting it all together will make it easier, but you can do it when your done if you want
Old Jul 18, 2007
  #159
LT2004ever's Avatar
^^y cant u use your brake lines that are on there?
Old Jul 18, 2007
  #160
Boilermaker1's Avatar
Jap-Euro Fusion
the fittings arent the same
Old Jul 18, 2007
  #161
LT2004ever's Avatar
Oh ok! gotcha, thanx boiler
Old Jul 19, 2007
  #162
JamesL's Avatar
JamesL is an unknown quantity at this point
I have a question fellas...
I finished up my rear disc swap a few weeks ago. After finishing bedding the brakes and whatnot, Ive started getting on them hard. The brakes work well enough, but I must depress the brake pedal further than when I had rear drums. This causes some difficulty in heel-toe-ing/etc. The ABS has a much more pronounced feel as well.
After reading the last 11 pages, Ive come to the conclusion that I should swap the stock Master Cylinder for the EP3's. For ***** and grins I would like to swap the proportioning valve as well...
Am I correct in assuming that the EP3 does not have a true front/rear proportioning valve? Would the DC5's work as well? Or would my best bet be something custom?
TIA.
Old Jul 19, 2007
  #163
JamesL's Avatar
Upon further investigation, it appears that the base DC5, EP3, and EX 7th gen all share the same brake booster and master cylinder... Can this be confirmed by anyone?
Old Jul 19, 2007
  #164
Jap-Euro Fusion
Thats probably correct considering they more or less all share the same brakes. You might want to pressure test the lines and/or bleed them, it shouldnt make any difference, or very little difference in the pedal travel.
Old Jul 20, 2007
  #165
JamesL's Avatar
Im going to try bleeding them again... although, it was done rather meticulously after the swap. But I will look into it.
You are saying that the prop. valve should have very little difference in the travel of the brake pedal, correct?
Old Jul 20, 2007
  #166
pon55's Avatar
Sometimes you just get cars that don't want to totally bleed. I've spent hours trying to get some bleed. Just keep at it
(this is assumeing you checked for any leaks)
Old Jul 23, 2007
  #167
JamesL's Avatar
Si senor. Im going by my my mechanic's tomorrow and we will check it out.
Old Jul 30, 2007
  #168
JamesL's Avatar
Spent a while re-bleeding the brakes... they are feeling absolutely great now!
Old Jul 30, 2007
  #169
pon55's Avatar
Old Jan 15, 2008
  #170
03lxDD's Avatar
03lxDD is an unknown quantity at this point
please help does anyone know if these will fit didnt want to start a new thread this is the reply i got from a guy seling them
It is USDM GSR spindle and caliper with an EP3 caliper bracket and rotor (4x100). This gives you a larger rear rotor on EG and EK civics... If you are still interested let me know..
thanks
Old Jan 15, 2008
  #171
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
^^ for a 7thgen? no it wont fit
Old Jan 15, 2008
  #172
D-Vus CIV's Avatar
my civic gets me pu**y.does yours???
D-Vus CIV can only hope to improve
does any know if the rsx base and ep3 disc are the same size in diameter?it seems like i have a 1/4 gap from the top hat to the area where the caliper touches.
Old Jan 15, 2008
  #173
streetthrowback's Avatar
streetthrowback should not be trusted
not sure but u can check by checking to see if they have the same part numbers
Old Jan 23, 2008
  #174
motorydr169's Avatar
motorydr169 is an unknown quantity at this point
ok i have read this whole thing and I know it has been asked before but i did not completely understand.
for the front brakes can i get a big brake kit for the EX (i have found one so thats not a prob)
for the rear can i set an 03 si brake kit and will that work on my 03 EX
Old Jan 24, 2008
  #175
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
brake kit as in rotors and calipers w/reloc-brackets if needed? you're still gonna need the spindles and e-brake cables
Old Jan 24, 2008
  #176
yeah. so if i get the brake kit will it fit? ill find the other stuff separately
Old Feb 22, 2008
  #177
stepchild's Avatar
stepchild is an unknown quantity at this point
I found the parts for $450.00 plus shipping. What do you guys think?
Old Feb 22, 2008
  #178
thats alot, i brought my setup for 200 shipped from a guy in canada
Old Jun 28, 2008
  #179
dariuscivic's Avatar
dariuscivic is an unknown quantity at this point
got a rotora big brake kit look into that
Old Aug 5, 2008
  #180
speedfoos's Avatar
I just did this using the rear disc setup from a UKDM 7th gen. Plug and play, nice and easy. Hardest part was laying on the ground in the junkyard pulling them off.
