HELP DEAD CAR!!
Old May 31, 2003
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
HELP DEAD CAR!!
I left my headlights on all day at school, when i came out to the car it was dead. I tried jumping it and sparks flew. I tried jumping it agian and nothing. So i went to sears and baught a new battery. I came back to school put it in and still nothing. Whats wrong with my car? Did i blow my fuse for my altinator and if so where can i find it? Thanks alot.
Old May 31, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
i dont believe hondas have fuses to the ALTERNATOR only ford and chevy if im not mistaking, any way 1st do you have a stock radio if so you need the code if you dont have the code take the radio out, try that first
Old May 31, 2003
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
when the sparks flew, you may have blown a fuse, but probably not. i guess it could be your starter, especially since you saw sparks fly with your old battery.
Old May 31, 2003
XxSoVeReiGNxX's Avatar
wow, good luck with your problem. If all else fails, tow your car back to Honda. Even though you left your lights on, they should be able to repair the starter or whatever may be the problem under warranty.
My car gives off a whiney noisey when I take the key from the ignition, while the lights are still on. But sometimes I don't even notice that until I'm about step out.
Old May 31, 2003
flotsamm's Avatar
So you get no dash lights or anything?
Old May 31, 2003
Whew i figured it out, when i tried jumping it i blew the battery fuse that was under the hood. I found this out after i baught a new battery and yeah our cars do have an alternator fuse its in the inside of the car in the fuse panel. But thanks for your help!
Old May 31, 2003
CarbonFly's Avatar
I thought you were gettin an NSX?
Old May 31, 2003
Civic is stilly my daily driver. The Nsx is in texas and i can hopefully pick it up by july.
Old May 31, 2003
Nice job! can you return the battery for a full refund? i hope so.
Old Jun 2, 2003
WhiteRabbit's Avatar
the alternator fuse is teh 80 amp fuse under teh hood. costs $10 from honda and was the most expensive fuse ive ever bought ;_;
Old Jun 2, 2003
kennisonxgs's Avatar
kennisonxgs is an unknown quantity at this point
Just wondering, did you hook up both positive and negative to your battery when jumpstarting?
twtron
Apr 17, 2015 12:09 AM
