My heater air is not hot at all
Hey guy i have a problem, when i turn the temp **** all the way down to heat the air flow goes down but the temperature remains the same at any position of the ****, what could be the cause of this problem? also, my indiglo gauges go on and off randomly for no aparent reason like every 10 min or so, what could be the cause of that ?? thanks for ur help
two weird problems at the same time. i dont really know whats wrong but for your guage, try looking at the fuse or make sure everything is connected tightly cuz something might be loose. as for your heater, did you install a head unit or removed that area? cuz it might have the same problem. if you still cant fix it, take it to honda and ask them.
A descendant of 2k1civic.com
Yeah and for the heater problem check your coolant make sure that it's full and test it to make sure it's good.
Also make sure that all your fuses are in good order and make sure that all your hoses, and lines are connected under the hood.
Heater problem could be a thermostat gone bad. If that's the case, get it checked immediately.
The indiglos flicker when you have alot of other accessories drawing on the power. Mine used to do that all the time. They need constant power to stay on.
Rob02Civic
Sep 16, 2018 09:16 PM
sonygenuis
Jun 30, 2015 03:35 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
mrohitredd
May 30, 2015 06:51 PM
jc33312
May 12, 2015 03:17 PM
