Squeak/ Drivers Side Rear........
Old Apr 6, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Question Squeak/ Drivers Side Rear........
Hey everyone, I have been listening to this squeak pretty much since I got my civic. It comes form the drivers side rear, somewhere in the suspension. The only time that this squeaking noise occurs is when I am taking a left turn and going pretty slow, like 10mph around a corner. This never occurs when I turn right, and when I turn left going fast. Does anyone know why this squeak occurs? Also, I just got rims on my civic and I am still under warranty. Is this particular problem covered under my suspension warranty, if it isn't void from getting rims? Id really appreciate you alls help. Thanks!
Old Apr 7, 2003
DaPipeLayer's Avatar
AAAAHHHHH!!!!!
DaPipeLayer is an unknown quantity at this point
What size are the rims? Did you have rims balanced at all? I don't think the rims will void the warranty unless they can prove that the cause of the squeek is from the rims. Make sure the rims are not rubbing against anything. You can also try putting the stock wheels back on in the rear and see if it still squeeks or you can put the front wheels on the rear just to see if maybe that one rim was not balanced properly. One last thing, make sure the lug nuts are screwed in tight.
Old Apr 7, 2003
Travii's Avatar
Travii is an unknown quantity at this point
I have that same problem I finally took my car into honda and I will see what they can do for me. I have stock wheels so I do not think your problem lies in your wheels.
Old Apr 7, 2003
ZSKCivic01's Avatar
Extreme Member
It has nothing to do with my aftermarket wheels. This has been happening since I got my civic. I just got my new rims about a month ago.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
ashlava71
May 16, 2015 12:54 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
