pinging (knocking) engine
Old Mar 25, 2003
CapYoda's Avatar
Escaped Convict
err. what cause this?
I think my engine is doing it.
its making the *dong dong dong* noise...
i haven't been driving it hard. not really.
I know I'm a bit pass the oil change... about 2,000 miles pass my usual every 3,000 miles
but that shouldn't cause it. normally its something like a hot spot in the cylinder, too low an octane fuel and ignition timing being off are other causes.
I know its not good. lol. if thats what I'm getting. although there seems to be diff. ones..
I dont hear it while accelerating.. only when I stop driving after like a long 30 mile drive and turn off the engine. then I'll hear something... it sounds like... well, literally sound like knocking and pinging... lol.
okay i should stop laughing cuz my piston might be burning to shread right about now...
any input?
Old Mar 25, 2003
CapYoda's Avatar
Escaped Convict
again. am I hearing what I think I'm hearing? cuz I'm under the impression that pinging occurs when er... you engine is actually on... not when u shut it off.
Old Mar 25, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
pinging/knocking will only occur when the motor is running. from your sig it says cali, but just a thought, my exhaust "pings" sometimes after a long drive and usually only when it's cold. It is the metal contracting and expanding so if you have an after market exhaust it might be something to look into. I can't really distinguish where the noice is actually emminating from because it just echo's throughout but it is definitly the exhaust. Im not sure if you are hearing it in your engine bay, if that is the case it could be something else contracting and expanding. If your motor is off, and your not throwing a CEL then it couldn't be a knocking problem. good luck.
Old Mar 25, 2003
doublins's Avatar
doublins is an unknown quantity at this point
actually, that's your catalytic converter... it sounds like someone is crumpling aluminum foil or something under your engine bay, right? Nothing to worry about at all, perfectly normal. Particularly after hard driving this will happen.
-Chris.
Old Mar 27, 2003
CapYoda's Avatar
Escaped Convict
oooh yeah now that I think about it, its more likely to be a exhaust issue... sounds like something is dripping sorta onto metal... yeah it happens sometimes, but sometimes it doesn't.
I guess I'm just getting paranoid.
thanks guys.
Old Mar 27, 2003
alphabios's Avatar
alphabios is an unknown quantity at this point
A co-worker of mine had this happen in a car he adjusted the timing on, he put Premium gas in his car and it was fine. After a while he was tired of paying for expensive gas so he adjusted the timing back to normal. Hell, for all I know he's a liar, but he tells the same story today as when I first heard it a few years ago.
At any rate, maybe your timing is off?!?
Old Mar 27, 2003
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Geeze CapYoda...nearly 2000 posts and 2 years on the board and you've never heard a car make those sounds after being turned off?!
Old Mar 27, 2003
CapYoda's Avatar
Escaped Convict
hahaha. I'm getting paranoid lately.
I've heard it before.. but I guess I've been reading too much and I'm starting to think I hear it on the road too.. which I dont. heh.
plus, when I turn off my car.. come on, I dont stick around and check it out.. I get my butt in the house.
:P
I know you're just playing.
Old Mar 27, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Talked about it in the VIP (Vehicles Issues/Problems) section. Do a little search there...
Conclusion:
-Most likely you need to put 87 octane from another fuel company (76, Shell, etc)
-If that doesn't help, put 89 for 2 gas tanks...
-If that doesn't work either, shaaaaaat...haha
I get the knocking noise too with Chevron 87... i put 89 and it disappears. (not completely, but noticeably)
Old Mar 28, 2003
CapYoda's Avatar
Escaped Convict
ooh yeah I forgot we got a VIP forum. heh. my fault.
yeah I read something like that too.. i'll try it out..
its weird I've been using 76 instead of Arco. which is what I usually use. lol.
that and chevron. maybe I'll go back to chevron.
Old Mar 28, 2003
branden's Avatar
branden is an unknown quantity at this point
as far as i know we have knock sensors on our cars, right? i don't know with LX models. but this should prevent it from happening.
Old Mar 28, 2003
PESTLNC's Avatar
No, we don't have knock sensors.
Old Mar 28, 2003
solar's Avatar
solar is an unknown quantity at this point
Could also be a problem with the EGR valve. Those things will cause a car to ping and get crappy milage. They're only on a D17A2 engine.
Old Mar 28, 2003
Mbow's Avatar
I don't think it has anything to do with the gas. Don't all cars make little popping noises and such after you turn them off? Seems like I have always heard cars doing that....I have no clue as to what makes those noises though...I just don't see how it could be pinging due to the octane if it occurs when the engine is OFF...if that is the case
Old Mar 28, 2003
PESTLNC's Avatar
You're right Mbow, but some people only read the first post and then click reply.
Old Mar 28, 2003
Mbow's Avatar
Well, I read the first few replies but didn't see that you had already answered the question...LOL
Old Mar 28, 2003
solar's Avatar
After reading Captian posts I was under the impression that the pinging noise happened when he drove, then he heard a different noise after he shut it off. ?????????? I guess now that I look at it I'm a bit confused.
Old Mar 28, 2003
PESTLNC's Avatar
Sounds like a bunch of marbles bouncing around inside your engine.
Old Mar 28, 2003
PESTLNC's Avatar
Weird, my post should be after Ronin's since it's 3:16 here.
Old Mar 28, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
You know, I don't think I have ever heard actual "pinging" from a running engine that's using too low an octane level.
Now that this pinging issue has been brought up again, what the heck does pinging sound like anyways? Does it sound similar to valves which are not properly adjusted?
Or does it sound more similar to a car cooling down after it's been turned off?
Old Mar 28, 2003
solar's Avatar
TEST: reply
I think that the ping noise is the same noise as a car with low octane fuel. A car with a bad EGR valve will do the same thing, but the computer will compinsate for it and the car won't seem to drive any different. The only noticable thing is bad fuel milage. I've replaced many EGR's in my day but most were vacuum controlled and the computer just monitored the exhaust gasses. Just my babbling 2¢
Old Mar 30, 2003
Ashock's Avatar
Ashock is an unknown quantity at this point
Hey my car pings when I go uphill. Using 87 Octane fuel. Anything I should be worried about?
Old Apr 2, 2003
solar's Avatar
Ashock, do you have a manual tranny? If you do just down shift to the next gear on a hill, and the ping will go away. If you have a auto it should down shift on its own. But don't worry about the slight ping if you get it going up a hill, it won't hurt anything.
Old Apr 2, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
i have been reading in a webpage that if you advance a cam gear too far, you will knock on regular gas, so use premium like what i do, eh better gas mileage too
Old Apr 2, 2003
solar's Avatar
Higher octane gas will not give you better gas milage, infact you might get less. Its one of the biggest misconceptions of high octane gas. Higher octane was developed to reduce valve ping under heavy loads, like punching the trottle from a start, passing, or hauling. It doesn't even increase horse power.
Old Apr 4, 2003
Ashock's Avatar
yeah i have auto
when it kicks down the ping is gone
yes higher octane fuel will only help with pinging
it makes you feel "oh i'm paying more money for better fuel so it'll increase hp and milage". NOPE! But the car does run better.
Old Apr 4, 2003
Chrissy's Avatar
i hear from some sources that our cars can run in gas as low as 85 octane. plz correct me if i am wrong. now i am now using 87, thx for the advice
danace99
23
Jun 28, 2015 08:49 AM
Supramk3
May 11, 2015 07:55 PM
BootyDo
May 7, 2015 04:46 PM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
