SRS>>>>>>>>>>???????
Old Aug 5, 2002
EuroCivic's Avatar
EuroCivic is an unknown quantity at this point
i just had my sparco seat installed....... then SRS light is now on permanently..... is that normal when seats are changed.... anything i could do about it....?
Old Aug 5, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
The yellow plug under your passenger seat connects to your airbag. (All yellow wires are airbag wires). That plug has to be plugged in, or the light will come on. Of course, now that you've started your car with that plug unplugged, the light will always be on until you either put your seat back in, or find some way to wire it differently, then follow the DIY SRS light instructions to turn it off. But don't screw around with your airbag wiring, 'cause you can kill yourself doing that.
P.S. I took mine to the dealer, talked to him for a bit, and he turned the light off for me. But that's only after I put my stock seat back in.
Old Aug 5, 2002
solar's Avatar
solar is an unknown quantity at this point
You have to have the wire under the seat hooked up or your Air Bags won't work. The seats should have been made for your application.
Old Aug 10, 2002
Connie's Avatar
What in the hell is SRS? I can't find anywhere what it means, I feel like a dumbass asking but oh well...
Old Aug 10, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
SRS=Supplemental Restraint System
Old Aug 10, 2002
Rider's Avatar
Rider is an unknown quantity at this point
The DIY have saved me money =) And reed it......2 min and it's done [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
