2004 Civic DX... Persistent A/C - alternator belt squeal
Old Aug 29, 2018
simplified's Avatar
simplified is an unknown quantity at this point
I did a routine timing belt / water pump replacement a couple of weeks ago, along with belts & hoses. Everything went like clockwork but now I have a persistent squealing problem with alternator - a/c belt. I have replaced the belt twice since the job, playing with different tensions each time. The compressor clutch and alternator spin nicely with the belt off. There are no oil leaks. A/C pressures are within specs and it blows cold. With the lower dust cover off I can see the compressor stall (and the belt squeals) when I have someone rev the engine. I tried Gates, Continental and Partsmaster belts. I have an OEM Honda belt ordered but have little faith that it will do the trick. The car has 91,000 miles on it and is stock / unmolested. I would appreciate any help or ideas... Thanks so much in advance!
Last edited by simplified; Aug 29, 2018 at 08:07 AM. Reason: Forgot to mention that the car is stock / unmolested.
Old Aug 29, 2018
Re: 2004 Civic DX... Persistent A/C - alternator belt squeal
Make sure belt is a good brand.
Does it squeal upon cold startup?
AC turned OFF, belt still squeals?
Don't play with different tensions. Tighten that belt until it doesn't squeal.
Old Aug 29, 2018
Colin42's Avatar
this
Baladce
Jul 20, 2020 05:09 AM
MonoDemon
Apr 1, 2018 10:02 AM
hpizzle
Jun 16, 2017 09:14 PM
JDM for Lyfe
Sep 8, 2012 01:29 PM
boosted.es2
Sep 18, 2006 01:54 PM
