Cmp please help
Old Feb 27, 2018
Secola's Avatar
Secola
Secola is an unknown quantity at this point
Cmp please help
I have been searching this site and forums for days now, cannot seem to find the answer I need. My engine light came on, had it tested, came up as the camshaft position sensor. I tested the wiring, it's all good, so I replaced the sensor. Based on what I'm seeing I should notice somthing wrong. I HAVE NO SYMPTOMS. No stalling, no limp mode, no starting issues, no loss of power. Nothing. What do I do next? I do not have the money to take it to a mechanic. TIA!
2004 civic si 2.0L
edit** engine light is still on, yes I reset it, it came back.
Old Feb 27, 2018
Re: Cmp please help
Post your actual "P" code.
What's the definition of code P0341?
Old Feb 27, 2018
Secola's Avatar
Secola
Re: Cmp please help
Code was p0344, intermitten interuption
Old Feb 27, 2018
Re: Cmp please help
Which cam position sensor did you replace?
Exhaust cam sensor? Intake cam sensor? Did you replace the wrong sensor?
Where did your new sensor come from?
Dangerzone? Honda dealer?
Could the plugs for intake cam sensor and exhaust cam sensor have been swapped?
With engine running.....Measure sensor wiring for excessive voltage on the ground wire
If higher than 0.20 volts:
Check that the ground wires under the fuel injector rail are clean and tight
Check, disassemble and clean corrosion from the terminals and bolts for the ground cable connections from battery to frame
Same for ground cable from frame to transmission
Same for ground cable from body to engine mount (passengers side)Pull valve cover,
Really far out thoughts:
inspect trigger wheel (reluctor) for the sensor in question: Does it have missing or damaged teeth? Is it loose on the camshaft?
Inspect sensor end for physical damage....excessive cam end play or 'walk'? (not likely)
black28
Engine DIY
21
Oct 9, 2018 09:46 PM
contevo
May 8, 2015 03:49 PM
crazyconfused5
Nov 26, 2011 10:25 PM
aznboi072001
May 11, 2009 02:11 AM
