Any tricks to seperating RTV joined components? (an oil pan in this case)
Old Oct 27, 2017
gts's Avatar
gts
gts has a spectacular aura aboutgts has a spectacular aura about
I'll be pulling the oil pan and figured it's gonna be on there tight (and a b**** to remove) due to the Honda RTV-type of sealant used (no gasket as it's an EX - D17A2 engine).
Anybody have any tricks/ insights for separating the pan from the block?
Old Oct 27, 2017
Re: Any tricks to seperating RTV joined components? (an oil pan in this case)
flat head screwdriver and some elbow grease. IIRC, there are cutout thingies where you can get a screwdriver into so you can pry them aaprt
Old Oct 27, 2017
mikey1's Avatar
a lot of patience and a large flat head screwdriver,
be gentle and pry all around, dont rush it or be rough, you dont want to damage the engine casing or warp/bend the pan
Old Oct 27, 2017
Judicious use of a prybar or screwdriver. I think the FSM might show the locations of the slots are to pry
I usually use
Old Oct 27, 2017
gts's Avatar
gts
Thanks guys. I ended up using used a prybar (carpentry prybar).
There was a location between the block and oil pan that seemed "made for" a prybar. One nudge and it came off like butter. Took about 2 minutes (literally).
I took some pics. Will post them when I get a chance so others can see the "sweet spot" for prying it apart from/ off the block.
Old Oct 27, 2017
gts's Avatar
gts
Now it's on to getting the pistons out.
Old Oct 27, 2017
Not hard to do. I was surprised how easy it was when I did it.
Good luck, and have fun. lol. Hope you have a piston ring compressor on you for reinstallation
Old Oct 28, 2017
Slumpertcivic's Avatar
Shame we can’t pull the pistons out from the bottom end....
My 2003 LX with 120k miles burning about quart of oil every 100 miles...
Keeping it topped off with oil till Xmas break when I will have a week to take apart and see if it’s just oil rings or time for JDM Vtec and all that hassle.
Old Oct 28, 2017
mikey1's Avatar
you can
Old Oct 28, 2017
you most definitely can.
Old Oct 28, 2017
^^Not with the crank in the way
