Srs code help
Old Oct 12, 2017
Caden Morris's Avatar
Caden Morris is an unknown quantity at this point
Srs code help
Hey yall. i am reading this code as a 21-2. is that correct? anyone know what this means?
Old Oct 12, 2017
Re: Srs code help
21-2 means 'increased resistance in drivers buckle tensioner circuit'
Will your local dealership cover it under the seat belt warranty?
Old Oct 12, 2017
Re: Srs code help
i thought that was 21-1?
hope so....they just charged me $50 for the diagnosis and replaced the passenger buckle. i thought that was 21-1?
Old Oct 12, 2017
Re: Srs code help
21-1 means OPEN circuit of the same item, as opposed to 21-2 meaning increased resistance.
Old Oct 12, 2017
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
Re: Srs code help
it's free replacement.. i just got the same code...
funny they didnt charge me diagnosis either
Old Oct 12, 2017
Re: Srs code help
That depends on the dealer. Not all will warranty it.
Old Oct 13, 2017
310civicEX's Avatar
310civicEX is an unknown quantity at this point
Re: Srs code help
id suggest going to a dealership that will to it free of charge... my tip for the day..lol
Old Oct 13, 2017
dsm482's Avatar
Re: Srs code help
they have to.. just ask honda usa to give them a call..
Old Oct 13, 2017
Re: Srs code help
they have to..
No, technically they do not....not for that particular problem.
If you read the warranty literature that came with the owners manual package when the car was new, most of them say only mechanical seat belt faults are specifically covered...not electrical issues.
If the buckle failed to latch, THAT would definitely be a covered fault.
Replacement for any other failure not specifically mentioned in the warranty guide might be left to the discretion of the dealer
And it might not need replacement anyway. ....but if the dealer will replace it and the code stays away, that's great.
FYI I have fixed many high resistance fault codes in various airbag system areas without replacing any components.
No tricks, just techniques for finding the problem and judicious use of specialized products to solve the problem.
Old Oct 13, 2017
310civicEX's Avatar
Re: Srs code help
in that case "it keeps unbuckling" that would get er done..lol
Old Oct 13, 2017
Re: Srs code help
It's gotta actually fail though. Someone at the dealer has to verify the complaint.
Old Oct 13, 2017
310civicEX's Avatar
Re: Srs code help
btw...
i hooked up those wires under my seat.. reset the srs light and it didnt come back... tried to check it for codes but it doesnt blink. i guess alls good.
