Cruise control issue
Hello all,
I'm having an issue with my Cruise control unit.
2003 honda EX manual Trans.
green cruise light come on the button when I push the button on the console.
however, when I set accel nothing happens in the dash cluster, no green cruise light.
checked fuses.
checked throttle cable coming from box
checked for vacuum leaks
brake lights are both working, not LED
any suggestions?
checked fuses.
any suggestions?
Re: Cruise control issue
check clutch pedal switch....and check if the little rubber pad is now missing... the switch plunger used to make contact with it
I Checked the pad, it WAS missing, I replaced it with a gromet for the door. and checked the switch it self for continuity. switch seems OK.
however, the issue is the same. there is another switch at the top of the Clutch pedal, and one for the brake, could these be an issue?
