CMC Problems?
Old Aug 15, 2017
RoseyEm2's Avatar
RoseyEm2 is an unknown quantity at this point
CMC Problems?
I recently did an engine swap and I was like why not buy a Goodridge Stainless steel linebsince I had everything apart. I changed out the line and the fluid looked like mud. So I was like **** good thing I changed it out. So I tighten up the line and everything to realize that my clutch pedal has ZERO pressure. I obviously know I had to bleed the clutch after I changed the line but the clutch pedal does not gain pressure at all. And any fluid just barely comes out On top of that I changed out the brake lines to Russell Braided lines and I bled the brakes and the brakes are like nothing. Any ideas?
Old Aug 16, 2017
Re: CMC Problems?
Sounds like air is trapped and won't come out.
Search the forum for various ways to bleed the clutch system.
