Does catalytic converter size matter?
OEM vs. Aftermarket: Does a significantly smaller cat make a difference in performance? Can it reduce flow and cause engine issues down the line? Wouldn't it cause some sort of carbon issues, or compression issues?
http://i199.photobucket.com/albums/a...psqd90trny.jpg
The legs in the public bathroom stall
Re: Does catalytic converter size matter?
Yes there are potential problems with aftermarket cats. The problems you listed are possible depending on how mis-sized the cat is. Also there is a good potential for check engine lights with p0420/430 cat performance codes which will cause an instant fail in any area that requires smog testing.
I would expect cat performance codes more than I expect to actually see carbon issues.
