How to prep Head Bolts?
2003 civic DX auto
hi, other than cleaning the Head bolt threads, should I apply antiseize or oil to the head bolts during installation?
The bolt holes are already clean & dry.
thanks!
thanks!
Re: How to prep Head Bolts?
When I did my head gasket (and ARP head stud install), I just put a layer of assembly lube on them during installation
I used this stuff because that's what I found at AutoZone. lol
Service manual says to apply fresh engine oil on the thread, washer and head of each bolt.
I just get a bowl of oil and dunk the ends of each bolt before dropping it in the hole.
agree with the bowl of oil,
i would throw all the nuts right into the bowl so they are submerged,
then just take them out one by one as you need them,
i do this with any internal nut or bolt....crank bearing bolts, cam bolts, etc etc
Ok Thanks!
I found my manual and brushed on the oil. I was afraid to put too much oil on the bolts as I didnt want to cause a hydro lock in the bolt hole as there are many warnings about cleaning out the bolt holes of liquids.
**The manual mentions hearing noise as you torque it down. -you have to restart the torquing of that bolt from the beginning. Is that really important cause I just kept going slow and always have had noises while torquing heads in other jobs?
The creak noises happen as the bolt stops and starts moving, this can make a torque wrench click out before the gasket is really clamped tight enough. So yes it's kinda important.
thanks
I torqued them 5 times in 2 days.
should I loosen them and redo the procedure or do you think it ok as it is?
