Replacing AC compressor 2001 CivicLX
Old May 21, 2017
BobStraus's Avatar
BobStraus is an unknown quantity at this point
I purchased a new Denso AC compressor with clutch. The plug on Denso has 2 live wires, the original has 1 live wire. Suggestions??? Is there an adaptor that they sell? Can I put the wiring from the old compressor and use on the new?? Something else I can do? Thanks
Old May 21, 2017
Re: Replacing AC compressor 2001 CivicLX
What are the two wires for? Follow them.
A hot and a ground for the clutch? A thermal protector?
Sometimes you have to adapt as needed using some of the original parts.....but you also have to understand what is necessary to make it operate before you can adapt.
Does it REALLY need a compressor?
Replace that bad fusebox first and see if the AC works again.
Old May 28, 2017
BobStraus's Avatar
I had an error in my original question. The Denso plug has 3 wires, while my original has only one.
Also, I have 2 civics. This is my car, the one with the multiple issues is my son's.
Old May 28, 2017
The single wire is for 2001 only.
The 3 wire version is for 2002-05.
