Car Stalling At Low Speeds
Old May 8, 2017
McCivic2005's Avatar
McCivic2005 is an unknown quantity at this point
Hi everyone, I have an 05 Civic with a manual transmission. When i slowdown to park my car in a driveway or parking lot, there are times when the car will stall for no reason when my foot is completely pressed on the clutch putting the car in neutral. I was wondering if anyone has any advice on where I can start with this, I have considered changing spark plugs but I have not looked to much into the problem yet.
Old May 8, 2017
Re: Car Stalling At Low Speeds
Clutch pedal position switch not working, not alerting the ECM to use its idle strategy when you push the clutch pedal?
Idle relearn needs done?
Old May 8, 2017
im going to try an idle relearn tomorrow and see if that does anything. If that doesnt work ill look into the the clutch position pedal thanks.
