Open in wire between IACV & ECM/PCM
Old Mar 9, 2017
EC3's Avatar
EC3
EC3 is an unknown quantity at this point
I recently got a p1519 (IACV Cuircuit Malfunction) in my 2003 Si. I followed these steps to diagnose the problem : http://www.hondafitjazz.com/manual/A00/HTML/98/SAA2E98K72100081143FAAT00.HTML
I got to step 13 and found not continuity between body ground and terminal A12. It tells me to "Repair open in the wire between the IAC valve and the ECM/PCM (A12).n" but I'm not really sure how to go about doing that. Any help, or comments appreciated.
Old Mar 9, 2017
Re: Open in wire between IACV & ECM/PCM
USA Si 2.0L, or Canadian Si 1.7L?
Old Mar 10, 2017
EC3's Avatar
EC3
Originally Posted by ezone
usa si 2.0l, or canadian si 1.7l?
usa 2.0
Old Mar 10, 2017
Ok, it's basically a 3 wire system...
The 3 wires are B+ (yel/blk), ground (blk), and a control or signal from the ECM (blk/red).
Which one is a problem? Did you confirm that wire is an open circuit?
Old Mar 10, 2017
EC3's Avatar
EC3
Im assuming its the signal wire (terminal 3 on my IACV connector). I grounded it with jumper wire (negative battery terminal disconnected) then checked for continuity on ECM connector terminal A12. There was no continuity, which means theres an open in the wire between IACV and ECM A12.
Im confused as to how I can verify and confirm theres an open. How do I trace that wire from the IACV to A12 or vice versa.
Old Mar 10, 2017
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
I had the same code with a different car and it turn out to be a bad IACV. Just go to the junk yard and pick up one.
https://www.civicforums.com/forums/3...1519-code.html
Old Mar 10, 2017
Did you ohm check the IAC valve itself?
Always confirm wire colors in a correct wiring diagram. It's too easy to hold a connector upside down or backwards and misdiagnose.
If you did the tests correctly, you have confirmed the open circuit. but it's darn easy to pick the wrong wires at the ECM, there are so many that look alike sometimes.
So if true, then the problem will be finding the open spot....it's somewhere between the ECM and the IAC valve. That black/red wire goes directly from the ECM to the IAC valve, there are no other connections shown for that wire in my diagram.
Look all along the harness bundle from the firewall and around the engine for rodent evidence, abrasion evidence, etc.
Might be easier/quicker to lay a new wire from "near" the ecm to "near" the iac. Make sure that's going to solve the problem before making it permanent. Splice where convenient.
Old Mar 10, 2017
EC3's Avatar
EC3
Thanks for all the help. Im gonna work on it some more this weekend, I'll post the updates
Old Mar 10, 2017
EC3's Avatar
EC3
It might end up doing just that
