Possible idle issue?
Old Feb 24, 2017
wildnorth's Avatar
wildnorth is an unknown quantity at this point
Unhappy Possible idle issue?
Hi there! I just recently bought a 2003 civic si and after about 2-3 weeks of driving around town, I've recently noticed a strange idle issue.
Whenever I tap the throttle or slow down to a stop, the rpms will sit at ~1500 for 3-4 seconds before returning to normal idle. I was wondering if anyone has had this issue before and if somebody could give me a few pointers on how to go about fixing it, as I have done some searching around and haven't really found any definite answers.
Any ideas would be helpful!
Old Feb 24, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Possible idle issue?
First thing I would suggest is to clean your throttle body/plate in case it is sticking from carbon buildup. Next would be cleaning the IACV. No CEL on with a code right?
Old Feb 24, 2017
wildnorth's Avatar
There is no CEL. This actually started about a couple days after I had changed my spark plugs. I got the exact same plugs that were in the car previously, and had gaped and torqued them to spec. A CEL did come on, but the car drove and sounded perfectly fine. So I took the negative battery cable off for 10 mins and reset it, and the light hasn't come back since. Since I did the reset, would it be possible that I might have to do an idle relearn?
I'll take a look and clean the throttle body/plate and the IACV once I get a chance.
Old Feb 24, 2017
Absolutely. Every time the battery is disconnected.....and you may need to disconnect the battery again before you begin the learn process.
Old Feb 24, 2017
wildnorth's Avatar
Nice!! Idle relearn seemed to do the trick. It's nice fixing problems for free, Haha.
Thanks guys! 👍
