Replace tumblers in lock cylinders
Old Dec 23, 2016
BigLeg's Avatar
BigLeg is an unknown quantity at this point
I've spent a good bit of time reading about similar issues to mine on this forum. I recently lost one of the keys to my 2001 Civic Ex and had the dealer cut a new one. The new key works perfectly in the passenger lock (hardly ever used), fairly well in the driver lock (somewhat used), not at all in the trunk lock (used often), and only in one direction in the ignition cylinder.
I want to replace the tumblers in the trunk and ignition cylinders with new ones, which I believe will fix the problem. I see Honda has the cylinder kit for $200+, but I only need a few tumblers. Is there a place where I can just get the tumblers I need? I plan on doing the work myself having watched several videos/how-to's.
Also, are there any other parts I should replacing (the cylinders themselves, etc)?
Old Dec 23, 2016
BigLeg's Avatar
Re: Replace tumblers in lock cylinders
I just took apart my trunk lock and now know which tumblers I need.
Old Dec 23, 2016
If your dealer has the tumbler kit, will they sell you individual tumbler wafers out of it?
ebay? Amazon?
Old Dec 28, 2016
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
As long as you have a few, it will work fine. It does not need all of them. Share them between locks in different positions.
