IDK what todo replaced clutch
i replaced clutch and put it back together started it and it went in first the actd like it was in nuetral even though i was sti in gear.2001 honda civic ex 1.7 manual trans d17a2
Re: IDK what todo replaced clutch
Axle not fully seated in the trans?
Inner CV joint came apart?
Does the speedometer show a road speed?
Have you double checked all of your work?
What steps have you taken to figure out the problem?
What have you observed as moving or not moving while the wheels should be turning?
