Ridiculous Overheating Issue
Old Oct 30, 2016
HondaGuy02's Avatar
HondaGuy02 is an unknown quantity at this point
I have read and studied and watched countless videos trying to pinpoint the issue of my 2002 Honda Civic EX overheating. I broke down 300 miles away from home and had to be towed all the way back. I have changed the water pump, radiator, coil packs, spark plugs, head gasket, timing belt, AC compressor, intake and exhaust manifold gaskets, Vtec Solenoid gasket, valve cover gasket, all 4 gaskets where the coil packs go. I have cleaned everything and been maticulous, 8 changed the oil and flushed all the coolant twice and my car over heats within a minute or two just idling. It maxes out the heat gauge and the coolant gets extremely hot. Before my car completely shut itself off going 70 down the highway it blew off a coolant cap. Then I replaced it. Again and again. It blew off coolant caps and hoses. I took the head to a machine shop and it had no cracks it was slightly warped but they fixed it. I don't know why my car is overheating and I don't have money to pay a mechanic to guess what's wrong with it. The fans aren't kicking on when I turn on the AC and I just replaced the compressor. Please help. Thanks.
Old Oct 30, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Re: Ridiculous Overheating Issue
https://www.civicforums.com/forums/3...reference.html
Take a look at this thread, it gives you a good place to start
Old Oct 30, 2016
HondaGuy02's Avatar
I already read all of that and as I stated above in my post. I have already changed the Head Gasket and Water Pump and all the parts that the thread you linked mentioned. Thank you though.
Old Oct 30, 2016
Wankenstein's Avatar
Overheating that quickly points to a failed thermostat. However, if you changed all that other stuff I assume the thermostat has been replaced though you didn't mention it. Another possibility is a clogged radiator.
When was the last valve lash adjustment performed?
Old Oct 30, 2016
HondaGuy02's Avatar
I haven't had/done one the entire time I've had the car and I don't know if the previous owner has either. It has a new thermostat in it forgot to add that. I recently took the head to a machine shop and they said something about them having to loosen something to move the camshaft and get the valves out of the way. When I tugged on a few of them. Some were tight and some had a little rattle to them. I made sure the car was completely bled and full of coolant also.
Old Oct 30, 2016
Read: https://www.reference.com/vehicles/s...f3e156c4ffa79#
Is it an OEM thermostat?
Call the machine shop and ask if they adjusted the valves.
Copy and pasted from this site https://forum.ih8mud.com/threads/eng...stment.265011/ :
"If lash is reduced beyond a reasonable amount, several things occur, all of them unpleasant. First, the valve timing is changed slightly, and this may affect performance, and emission outputs. But there is an added complication: The exhaust valve stays alive because it's able to transfer a fair portion of the heat it absorbs from the combustion process directly into the cylinder head when it's resting on its seat. As clearance is reduced, the valves spend less time on their seats. This means the exhaust valve(s) has less time to give up its heat, leading to anything from detonation, pre-ignition and engine overheating, to a warped or burnt valve."
Here's more: https://www.google.com/#q=valve+adju...ly+overheating
Old Oct 30, 2016
HondaGuy02's Avatar
Thanks for this. I'll check the radiator and see what the machine shop did. The thermostat isn't an oem. It's a crappy one from autozone.
Old Oct 30, 2016
Even if the head gasket job was done perfectly, a single overheat event can ruin all that work in a heartbeat.....so you could still be fighting multiple issues.
