04 lx rough idle
Old Oct 26, 2016
Civic LX of Tim's Avatar
Civic LX of Tim is an unknown quantity at this point
04 lx rough idle
So I'm trying figure out what is causing my rough idle & how to fix it.
I replaced the spark plugs and the ignition coils - no change.
I'm going to put Lucas in the gas tank today & see if that helps.
I adjusted the idle on the accelerator cables, that's not really working either. Help!
Thanks.
Old Oct 26, 2016
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Re: 04 lx rough idle
if it was me first thing I would look at would be the idle air control valve. take it off clean it put it back on and see if that helps your issue. Look it up on you tube if you have never done it before, its easy to do. Check to see if there is a check engine light, if so what code is it. good luck.
Old Oct 26, 2016
rough idle
Probably need to nail down exactly what is "rough" about the idle before trying to toss parts at it.
Old Oct 27, 2016
too late for that.
