Oil Leak on top of engine...
Old Mar 24, 2015
Pilvr83's Avatar
Pilvr83 is an unknown quantity at this point
Hi,
I have a 2003 LX that leaks oil from the top of the engine near a plug like thing with wires that goes to the valve cover/spark plug area. It is near the passenger side. I cleaned the oil off and discovered it is leaking near the plug. Not the plastic cap on the side.
What is this and is it easy to replace/repair?
Thanks
Old Mar 24, 2015
Re: Oil Leak on top of engine...
Is it oil or antifreeze?
Clean it all spotless using spray brake cleaner.
Coat the area with ordinary white talc, spray right guard, baby powder or foot powder.
Drive it until the leak shows itself, there should be a clear trail left in the powder leading to the source.
I'd usually suspect the round plug but that usually pools oil directly below it.
The other normal choice is the valve cover gasket.
HTH
Old Feb 15, 2016
jdawgzcivic's Avatar
jdawgzcivic is an unknown quantity at this point
Hi,
I just discovered I have the same exact issue on my daughter's 2003 Honda Civic. Were you able to locate and fix the issue?
Thanks
Originally Posted by Pilvr83
Hi,
Thanks
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
671civicLX
Jun 13, 2015 05:56 PM
Nigel Evans
Jun 10, 2015 06:35 PM
davidpaustin
May 20, 2015 12:59 PM
