alignment problem
Old Jan 22, 2015
civicowner123's Avatar
civicowner123 is an unknown quantity at this point
alignment problem
I have a honda civic 04, coupe. The front left tire could only hold so much air, and so was flatter than the rest. It stayed like this for about 2 weeks. It cause my car to want to turn to the left a little bit, and so I had to turn the steering wheel a lil bit just to keep it going straight. Well, I eventually got it patched, and noticed that the car still wants to turn to the left, so I rotated my tires, and then checked psi levels of all tires, and they're all at 35psi. The problem is still occurring. What can I do?
Old Jan 22, 2015
Poopies's Avatar
Super Moderator
Re: alignment problem
Get an alignment done?
Old Jan 24, 2015
I'd like to do it myself. Isn't an alignment where they just switch tires around?
Old Jan 24, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Yes, you can check it yourself. Only adjustment is toe in. Jack each side up and manually spin tire while coating a center smooth area on the tire all way around with chalk. Now, keep it steady on a grooved heavy block, scribe a line with a sharp pencil or scribe all way around. Be sure that line does not waver. Lower car and carefully jack under each ball joint to get wheels sitting where they normally rest. (dropping from a jacked up position leaves them inward) Now with a helper, carefully pull tape same distance up on from ground front and back side of tire measuring distance. I made me a beam with uprights so I can do it by myself and get up to center of wheel. The front distance should be just slightly less. (toe in slightly less to a 1/16"..makes the car go straight) Same on back. tires. All other stuff is fixed. Your pull is probably tire wear on the edge. Put the front tires on the back of the car. However, once all are worn, little you can do. You should get all four new tires, have a dealer align it. and rotate them front to back ever 5K and stay off curbs and deep holes.
Old Jan 24, 2015
Front toe spec is actually zero.
civicowner123
Jul 24, 2015 10:02 PM
honda200192
May 31, 2015 05:57 PM
bo_red
Apr 23, 2015 10:09 PM
dret
Canada West
Jan 8, 2002 03:05 PM
RickyRocket
Nov 30, 2001 10:14 AM
