Timing the camshaft on honda d16y7
Old Sep 15, 2014
J.P.M.'s Avatar
J.P.M. is an unknown quantity at this point
Red face Timing the camshaft on honda d16y7
well I've been having trouble timing my Honda del Sol d16y7engine year 1997. my timing belt broke while driving down the road, so I decided to replace the cylinder head along with timing belt water pump tensioner pulley. I've gotten as far as timing the engine. There is lots of information on the Internet on how to get your #1 cylinder to top dead center, and I've done that: also the camshaft pulley lined up with the marks to the top of the cylinder head. But as I see it, the camshaft has the potential to be out, 180 degrees; meaning the valves will be either open or closed at the right cylinders or the wrong cylinders. So my question is; is this true? And if so, how do you get your cam shaft to number one position? Remember, I am trying to time the camshaft separately from a crankshaft without the timing belt. From all the information I have gathered on my car; the firing order is; 1.3.4.2.
Old Sep 15, 2014
mikey1's Avatar
Re: Timing the camshaft on honda d16y7
be very careful, you could damage valves here very easily,
if your crank is at TDC i would rotate it 90 degrees in its direction of travel, this will put all the pistons half way up the cylinders and clear of the valves,
at this point its now safe to rotate the camshaft to TDC
after you do that, turn the crank back to TDC in the opposite direction of travel back the 90 degrees,
remove your spark plugs to make it easier to rotate the engine
sharp66
31
Jun 12, 2022 08:45 AM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Bartkat
20
Feb 19, 2002 01:29 PM
