Rough Noisy engine at certain rpm
Old Aug 11, 2014
ashokudu's Avatar
ashokudu is an unknown quantity at this point
2001 civic dx, manual with a/c. 228K miles.
Recently changed front motor mount & timing belt. Now engine runs rough or vibration, more noticeable in the cabin than at engine.
I rechecked my timing marks, they line up perfectly.
The idle is at 700rpm once it warmed up. Rev up fine, no lag or any noticeable power difference.
Thinking it is the motor mount, which is a very cheap one i bought from amazon.
any ideas.
Old Aug 11, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Re: Rough Noisy engine at certain rpm
Sounds reasonable to replace the motor mount. https://www.civicforums.com/forums/1...re-buying.html
Old Aug 11, 2014
Use OEM Honda mounts.
Also, some of the mounts are different between coupe and sedan or auto/manual, maybe they sent you parts for the wrong car.
Old Aug 11, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
^That.
Since the two transmissions have a pretty big difference in weight and how it's distributed in the car, not to mention attachment points on them... auto and manual trans mounts will definitely be different.
On my old Escort auto, had looked up the mount for the rear of the drivetrain, as apparently on these 90s models, they lasted about as long as a high student getting his nasty on after prom. The manual and auto versions of the same mount couldn't be more different. Swapping them with each other is asking for NVH (noise, vibration, and harshness), not to mention possibly even shorter service life.
Old Aug 11, 2014
Neutralize the mounts? Check it out here: http://honda-tech.com/showpost.php?p=36669793&postcount=16
Old Aug 11, 2014
kinakoes2's Avatar
Yep -- another good tip. On my Escort it was waaaay more ghetto and involved than the Honda version... but the result, even on the infamously-box-o'-rocks-down-a-cliff SPI engine, was a super-smooth idle. Not so much with just slapping the mounts in (this of course with OEM mounts... with aftermarket ones, you're on your own).
jbradley4809
Apr 7, 2017 04:23 AM
beneditti
Jan 15, 2016 12:31 PM
Wild Cranker
May 19, 2015 06:10 PM
crowtoo
May 11, 2015 06:50 PM
Ninetyatecivic
May 9, 2015 07:48 PM
