2003 Honda civic radiator fans
Old Jun 9, 2014
GifTed1's Avatar
GifTed1 is an unknown quantity at this point
My son has a 03 Civic. It has 2 radiator fans. I noticed the other day when he had his hood popped up that just 1 fan was running. I unplugged the wires from the running fan and plugged them into the fan that wasn't running. To verify that the non running fan motor wasn't bad. It turned on when plugged in. So my question is....Are they both suppose to be running? Does one run and the other kick on and off as needed? Do they have different temp sensors? I havent found a direct answer to that yet in the forums. How Honda has it set up. Thanks
Old Jun 9, 2014
mikey1's Avatar
Re: 2003 Honda civic radiator fans
its normal, the fan that was not running only runs when you have the A/C on
Old Jun 9, 2014
GifTed1's Avatar
Ok. Thank you.
Old Jun 9, 2014
03 should have both fans running at the same time every time they run, no matter which system turned them on.
Look in a wiring diagram.
Old Jun 11, 2014
pro-cognizant's Avatar
pro-cognizant is an unknown quantity at this point
Just had this problem, easy solution is check the fuses/relays. The two fans have separate fuses and relays in the underhood fuse box (I believe they are both 20amp fuses). If one works and the other doesn't, but does when wiring is switched, it is almost assuredly that.
jessicakaybby
Apr 20, 2015 12:11 PM
prowl
Apr 18, 2015 07:50 PM
dooner24
Apr 14, 2015 07:51 PM
