ac help
Old May 29, 2014
evansdad331's Avatar
evansdad331 is an unknown quantity at this point
ac help
ok took my 01 coupe to the dealer yesterday, because the ac isnt working, its blowing hot air, well everything works when the tech uses the honda computer to control everything. they said the the control unit might be bad. the ac button and recirc button lights up as its on but no compressor and it just blows hot air. has anyone had this issue, the srs and brake light is on. and after i left the dealer the check engine light is on but its off now. ppppplease help a brother out/
Old May 29, 2014
mikey1's Avatar
Re: ac help
are you saying the dealership was unable to diagnose the problem?
Old May 29, 2014
Re: ac help
Maybe it wasn't acting up while they had it.
It happens to me a lot. It's like the cars just know....
Old May 29, 2014
Re: ac help
yes the dealer couldnt figure it out, and it was acting up while they had it. he could engage the compressor and everything by the computer. he didnt know if it was electrical a switch or computer. it goes back in tuesday
Old May 31, 2014
Re: ac help
anyone know why the ac light and recirculation light is constatly on?
Old May 31, 2014
Re: ac help
The switches are simple inputs to the HVAC controller, and the lights are operated by the HVAC controller.
So.... I'd reason the HVAC controller is keeping those lights on, for whatever reason.
Does that mean it's bad? Maybe.
Let them give you their answer.
Old Jun 20, 2014
Re: ac help
thanks to everyone and the posts on here, the honda tech couldnt find the problem and through these forums i found the problem mcu!!! and i changed the fuse box and all my issues were fixed, no door locks, no intermiting wipers all my chimes, ac, brake light, and yes i went to the dealer and got it, no headaches with wrong part, ie 4door to 2 door and whatever, and got a 1 year warranty.
Old Jun 20, 2014
Re: ac help
Ya know, if you had mentioned you had issues with all these other systems along with the AC problem, I could have gone right to the MICU.
Except the MICU shouldn't have anything to do with the lights on the AC/recirc/def switches. That's probably in the HVAC controller.
