Oil Leak in spark plug area
Old May 2, 2013
jback2211's Avatar
jback2211 is an unknown quantity at this point
The 1st spark plug chamber or tube( as you are facing the engine,cylinder #4 I think) was near filled with oil when I changed plugs. I see several seals on the ignition coils. What should I change to repair this leak.? Is there something other than the ignition coil seals. Thanks in advance.
Old May 2, 2013
mikey1's Avatar
Re: Oil Leak in spark plug area
you need to remove the valve cover, there are 4 round rubber seals that seal around the holes for the spark plugs, might as well change them all while you have the valve cover off
Old May 2, 2013
jback2211's Avatar
Thanks for the quick reply, I will do it. Thanks
Old May 2, 2013
Read this thread: https://www.civicforums.com/forums/3...her-issue.html
This is what I see most often on 7th gens, usually after someone had the valve cover off.
LionSpratt
Jan 29, 2017 11:07 PM
danace99
23
Jun 28, 2015 08:49 AM
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Micks2K1
Dec 10, 2001 07:11 PM
