CKP Sensor Problem in 2002 LX
Old Feb 23, 2013
echosmyron's Avatar
echosmyron is an unknown quantity at this point
Hello,
My 2002 LX stalled on me a week ago and the malfunction indicator light came on upon re-ignition. Since that time, the car has intermittently had hard ignitions and stalled on me an additional time. I had the OBD code read and was told it was a problem with the crankshaft position sensor, although I foolishly forgot to copy the exact OBD code down. I know I should get the exact code down, but was wondering whether the CKP could be the cause of the problems I've been experiencing, as I've read elsewhere on the forum that the real culprit behind such a reading could be the distributor.
Thanks a lot for your time.
Old Feb 23, 2013
Re: CKP Sensor Problem in 2002 LX
Get that info.
Yes.
If it really is a CKP code, pull the connector off and look for evidence of corrosion of the electrical terminals in the sensor and its connector. Somewhat common problem with water getting in there and causing problems.
Post a picture of your distributor first.
Old Feb 23, 2013
mikey1's Avatar
Old Feb 23, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Damn. And I thought I was a dikhead. Oh wait, I still am.
Old Feb 23, 2013
What?
I asked for a simple pic of the distributor on OP's 2002 Civic LX 1.7L.
Just wanna verify what we are dealing with here.
What's so dikheadish about that?
Old Feb 23, 2013
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Those engines do not carry distributors. They use coil packs instead.
Old Feb 23, 2013
Matt_75's Avatar
Yeah, ezone. You didn't know that?
Old Feb 23, 2013
SHHHHHH!
We're still waiting for the pics.
Old Feb 24, 2013
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
When you buy the CKP sensor make sure it is in a sealed bag.
If it's not sealed you will likely be replacing it immediately due to buying a bad (used) sensor.
Buy a Beck/Arnley sensor.
Nathan
sharp66
31
Jun 12, 2022 08:45 AM
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
bo_red
Transmission
May 3, 2015 09:14 PM
