new 2002 honda civic si need help
Old Oct 14, 2012
cona's Avatar
cona is an unknown quantity at this point
im new to cars and to this forum, so please go easy...
i got a honda civic about a 1 1/2 months ago
i just rechecked all my fluid.
i noticed that my oil is really low, close to none... i checked under the car (cause its been sitting in my garage for 3 days) and i see no leaks.
does oil just get used up that quickly?
do i need an oil change or do i just need to put more oil in it..
what kind of oil is best to use for an 02 civic si?
side note: ive been using 91 gas on my car... is that alright?
thank you
Old Oct 19, 2012
Sherlock's Avatar
Sherlock is an unknown quantity at this point
Smile Re: new 2002 honda civic si need help
As far as oil goes you may want to fill and check every day to see if its being burnt or leaking. if its low you may not be at the level to have it leak out see what Im sayin.
91 gas is okay to use but if you switch to something else later on like a year from now your car will run like ****. just use mid grade and it will be just as good.
if after you fill your oil and it just houdinis on you no leak puddle or nothing then you are burning oil. most likely you need new rings on the pistons which is super expensive to have somebody do.
Oh as far as oil goes just look in your owners manual or ask the guys at auto zone they will tell you
Anyways if you have anymore questions hit me up
jessicakaybby
Apr 20, 2015 12:11 PM
vino
Nov 3, 2001 11:08 PM
