My Civic is leaking oil, already replaced the Cylinder Head Cap, and Valve C Gasket.
Old Aug 31, 2012
jeffyoshiyuki's Avatar
jeffyoshiyuki is an unknown quantity at this point
http://imageshack.us/photo/my-images/515/img1841y.jpg/
http://i5.photobucket.com/albums/y16...r/IMG_1842.jpg
you can see the leak kinda from the video. The Video is of the Left of the Valve Cover. its leaking on top of the bellhousing and spilling everywhere.
Old Aug 31, 2012
Re: My Civic is leaking oil, already replaced the Cylinder Head Cap, and Valve C Gask
its an automatic 2001 Honda Civic LX
Old Aug 31, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Twisted valve cover gasket possibly. Did you torque the valve cover to 86 in/lbs in the correct torque sequence? Did you put RTV on the corners where the valve cover curves for the camshaft? Did you use an OEM valve cover gasket? I've seen problems with after markets where they won't stay seated well in the valve cover.
I would take the valve cover off and inspect the gasket. I've had this happen to me before, but I it was twisted in the rear.
Old Aug 31, 2012
the rounded corners?
Old Aug 31, 2012
Matt_75's Avatar
There are flat spots on the valve cover gasket that should have a dab of RTV on them where it meets the camshaft.
Old Aug 31, 2012
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
I can try to get a picture of the area for ya, but looks like a cam plug to me. The transmission end of the cam has a plug in the end of the bearing cap, look there. It is a plastic plug, but it has an oring. Pop it out pop the new in. Your egr doesn't have to come off, but it sure helps. It is pretty tight with it in there.
Old Aug 31, 2012
Matt_75's Avatar
I thought he said he replaced that in his title "cylinder head cap". I could be wrong.
Old Aug 31, 2012
that was the 2nd item I replaced.
well i used RTV or what ever its called to seek the valve cover gasket. (i put it on the "flat tabs" of the gasket and the U parts of the gasket. im gonna let it dry overnight.
Old Sep 1, 2012
Matt_75's Avatar
I took a closer look at the pictures and can see you didn't use an OEM valve cover gasket because it's blue.
Old Sep 1, 2012
I found the source of the leak,
http://i5.photobucket.com/albums/y16...r/IMG_1849.jpg
http://i5.photobucket.com/albums/y16...r/IMG_1850.jpg
it is dripping quite considerably under this item.
Old Sep 1, 2012
Matt_75's Avatar
That looks like the VTEC solenoid, but you said you have an LX. I don't know what that is for an LX.
If it was the VTEC solenoid, the first picture would be of the oil pressure switch and the second, the solenoid it self.
If it was an EX it would be part of piece 9 in the below drawing.
http://www.hondaautomotiveparts.com/...EAD+%28VTEC%29
Old Sep 1, 2012
sorry its an EX
http://i5.photobucket.com/albums/y16...r/IMG_1851.jpg
pulled it and it was covered and dripped of clean oil
Old Sep 1, 2012
have these been known to leak?
Old Sep 1, 2012
Matt_75's Avatar
Sure. Anything can leak that has a gasket.
You might want to consider replacing the oil pressure switch o-ring as well since you already have it off the car and apart.
Old Sep 1, 2012
Matt_75's Avatar
I'm sure it was clean oil as much as you probably had to put in it to keep it full. That was a pretty serious leak.
Old Sep 1, 2012
Matt_75's Avatar
BTW, thanks for starting this thread. I went out and checked mine and it looked like there was some weepage under it.
I went to my dealer and bought all three gaskets and just now replaced them. So again, thanks for starting this thread.
Old Sep 2, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
^^^^ Do what he did.^^^^
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
thesushiboy
Apr 12, 2015 02:54 AM
