2001 Honda Civic HX 1.7L P0303 Misfire cylinder #3
Hi,
I have a 2001 Honda Civic Hx with 160,000 miles and I am getting a code P0303 Misfire on cylinder #3. When the car is at a stop and idiling the RPM's go low and the car starts shaking and when I turn on the AC the car starts shaking even more and it makes a squeaking noise. Would this be a coil or my time belt causing this problem?
7th Gen Civic DIY Enthusiast!
Re: 2001 Honda Civic HX 1.7L P0303 Misfire cylinder #3
Hi,
The squeaking sound is probably coming for your drive belt that goes around your compressor and alternator. No way of knowing for sure with out listening to the problem.
You could also check the coil pack to make sure it's seated properly as well.
Did you use OEM plugs?
You could have coolant leaking in that cylinder causing the misfire because your head gasket is blown.
LionSpratt
Jan 29, 2017 11:07 PM
ashleymmackey
Apr 18, 2015 09:48 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
