Temp Gauge at half all the time
Old Apr 30, 2012
Sailorman3's Avatar
Sailorman3 is an unknown quantity at this point
I had a issue with my civic overheating over the weekend. Turned out to be a stuck thermastat which I have fixed. The problem that I'm having now is that the temp gauge is reading just above half now all the time. The car sat for 2 days, went to start it, just over half right away. Drive it anywhere. Just over half. Turn the car off, temp indicator goes to the bottom. Turn it on just over half. The car is not showing any codes. Anyone with ideas???
Old Apr 30, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: Temp Gauge at half all the time
I'm not 100% sure on this one but it might be the temperature sensor.
Old Apr 30, 2012
CEL on? Troubleshoot the check engine light first.
Plug a scanner in and read the coolant temp that the computer sees.
If the PCM reads the wrong coolant temp, then unplug the sensor and see it if reads -40F. (It should.) Probably replace the sensor for being inaccurate. (The engine would probably run poorly too.)
If no joy,
Next is troubleshoot the multiplex unit for codes.
Then do a self test on the gauge cluster.
See if the needle makes a full sweep during the self test, and see if any relevant info is revealed during the self tests.
The how-tos should all be in a good service manual.
Try a reset: disconnect the battery cables and hold them together for at least one minute. Reconnect and see what happens. (Don't forget to do an idle relearn.)
The cluster relies on data from the PCM to operate the gauges. If nothing above got you any answers, then it's either the PCM or the cluster.
HTH
Old Apr 30, 2012
Sailorman3's Avatar
No check engine light is on. When the sensor is disconnected it does read -40. I'm leaning towards the sensor also.
Old Apr 30, 2012
So...you have a scanner?
What does the temp read in the datalist when the engine is stone cold? Sitting overnight should leave the IAT and the ECT reading within just a couple degrees of each other (and ambient temp) before running the engine---easy check.
This should tell you if the sensor is accurate or not.
Old May 5, 2012
Sailorman3's Avatar
Finally got around to replacing the sensor today. Everything is fine now. I found that the sensor had a crack in it at the top. When that sensor is gone it even makes the car extreamly hard to start, but if you disconnect it, the car will start fine. Thanks for the input.
Old May 5, 2012
BlueEM2's Avatar
Whachya lookin at?
Sweet Glad we could help, even though it seems you had it all under control.
Old May 5, 2012
Sailorman3's Avatar
Always good to have a fresh perspective on issues that can be several different problems. Thanks again!
Xuhme
21
Aug 7, 2023 03:40 PM
werdnahall
May 17, 2015 11:37 AM
Rushfan1
May 6, 2015 01:20 PM
tylerginevan
Apr 27, 2015 12:29 PM
