overheating, cant figure it out..
Old Aug 31, 2011
mmawson315's Avatar
mmawson315 is an unknown quantity at this point
ive got an 05 civic ex se coupe 1.7 mt vtec that ive had for 1.5 yrs. love it, no problems till now. it started leaking coolant a couple times, not continuously, after i drive it kinda hard. and determined it was coming out of the resivour, which was overfilled almost to the cap. mind you, i havent put any coolant into the thing. i took off the radiator cap to see if the seal was bad, and it let out a huge gasp of air and the level in the res went down to normal after i ran it once, so im assuming air pocket. the next day it started overheating and the coolant level went back up. the next day (yesterday) i tried getting it to overheat again to see if its consistant, nothing happened. i changed the thermostat cause its quick easy and cheap, then i tested the old one and it still worked.
anyone have any ideas? im lost
Old Sep 9, 2011
bzackrie's Avatar
bzackrie is an unknown quantity at this point
Re: overheating, cant figure it out..
head gasket
Old Sep 9, 2011
lazlong's Avatar
Originally Posted by bzackrie
head gasket
To elaborate, have the coolant checked for exhaust gases before you rip half the engine bay apart to do the timing belt/water pump.
Old Sep 9, 2011
seems to be a common problem with these cars.
GritzNGravy
Aug 19, 2015 03:03 AM
Dangerousjordan
Jul 30, 2015 11:19 AM
cyc
Jul 22, 2015 01:14 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
