Help! No rpms/speed Cat converter or what?
Old Jul 25, 2011
myride88's Avatar
myride88 is an unknown quantity at this point
Exclamation Help! No rpms/speed Cat converter or what?
Just bought a 01 Civic last week. Changed the oil and checked the air filter like Thursday. Bf sprayed carburetor cleaner in the engine and car started reving (pulsing) between 1 and 2k rpms. Next day it was fine. Yesterday was the first long distance drive. Went 25 miles and ck engine light came on and car wouldn't accelerate past 2000 rpms or 30 mph. When I let off t he gas and the rpms dropped, the engine cut off. I let the car set for a while and it is running fine (ck engine light off) until it warms up again. What happened? Codes: p1457, p1361, and p1362
vtech engine manual transmission
Old Jul 25, 2011
Re: Help! No rpms/speed Cat converter or what?
i doubt the carb spray did anything, as the codes are unrelated. the EVAP emissions system would not affect how the car runs (this system recycles and burns gasoline vapors from the tank as a fuel saving feature). the other codes are for a bad TDC (top dead center) sensor on the engine. this is a big one and tells the computer how the engine is turning. i would not recommend driving the car until it is replaced because permanent damage can result.
P1457 EVAP Emission Control System Leak Detected (Control Canister System)
P1361 TDC Sensor Intermittent Interruption
P1362 TDC Sensor No Signal
Old Jul 25, 2011
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Could be wrong but the first one could be just from a loose gas cap.
Old Jul 27, 2011
myride88's Avatar
Well I just paid a mechanic to diagnose my car and change the TDC sensor... My Bf drove it about 15 minutes and the ck engine light came back on and the car is exactly the same... won't accelerate more than 2k rpms... The mechanic said I may need to have the cylinder head replaced but doesn't think thats the issue. What Do I Do?!!!! I don't want to rebuild the car....
Old Jul 27, 2011
is the engine light back on for the TDC sensor? if it is, the mech installed it wrong or used a crappy non honda sensor.
Old Jul 28, 2011
myride88's Avatar
The mechanic just called me and said that the engine light is on but only has a code for the Catalytic Converter.... can that cause the car to have the same issues?... Mechanic says that I need to get a new Cat and that should fix it...
Old Sep 21, 2011
myride88's Avatar
Update to car issues
Well... after changing the TDC sensor, catalytic converter and oxygen sensor... the car finally runs without breaking down, however, when the car heats up, I smell a burning smell kind of like a hot iron... The mechanic said that its just the new cat converter... but thats been over a month ago. Any idea why it still smells like its burning?
even though this car has given me more problems than all other cars I've had, I still love my Civic!
Old Sep 22, 2011
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Yeah a day or two is normal for burning crap out of the exhaust area for some sort of exhaust maintenance, but a month, there's something wrong there if it still smells.
There may be something bigger in the exhaust where it was disconnected sitting on top of the cat.
What model is this an lx,dx,hx,gx or ex?
I ask this because it makes a big difference where the catalytic converter is located. If it's an lx, dx, hx, gx then the cat is located right on the exhaust manifold and you may need to remove the exhaust manifold to see if somethings sitting on top of the cat screen and maybe causing the burning smell. There might be something in the down pipe as well, but not likely.
If it's an ex then the cat is located much further away and you might not smell something stuck down there burning.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Luluharp
Sep 27, 2015 11:56 AM
blizza
Sep 20, 2015 04:09 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
dantheman42
Sep 4, 2015 01:10 PM
