im done nd need help asap
Old May 14, 2011
floyd107's Avatar
floyd107 is on a distinguished road
Angry im done nd need help asap
ive had this problem for almost a year and just want it away. my 02 civic lx runs rough as **** at idle BUT my rpms remain steady. it almost feels like i need new motor mounts but they all were just replaced.mind you it is VERY rough the whole car rattles and i can hear the deep vib sound. the problem suddenly happend one day while driving like normal.the car just got reall rough.
idk if it is possible that my fuel system can possibly be that dirty being that i use the injection cleaner. is it possible my fuel filter is so dirty that the cleaner just isnt working or maybe my timming is off slightly. would that cause anything like that.
well please anybody give me your input even if you not 100% sure just so i can cross it off the list.
Old May 14, 2011
Re: im done nd need help asap
if you car drives fine, then you can rule out fuel system. it uses the least gas at idle. did you do the usual cleaning of the idle valve? also check the mounts, the front one you should be able to feel if one or more legs are torn.
Old May 14, 2011
floyd107's Avatar
no because im not sure which one that is can you post a pic so i no(idle valve). and maybe the vacuum hoses can be damage.
Old May 14, 2011
MindBomber's Avatar
Live for the Twisties
A deep vibrating sound at idle sounds a bit like you might have an exhaust leak..
Old May 14, 2011
https://www.civicforums.com/forums/1...e-up-mods.html
Old May 15, 2011
lazlong's Avatar
Like mentioned above, start with cleaning the IACV and throttlebody. Might not be a bad idea to check for codes too.
Old May 15, 2011
floyd107's Avatar
ok i cleaned the throttle body,iacv,intake and the pcv valve and it dident change anything. maybe my fuel rails? or maybe inside my intake manifold is cloged somewhere? and as for my vacuum lines are they supposed to be filled with anything because i noticed a tag that said ''EVAP SERVICE PORT. 1PSI MAX.REGULATED PRESSURE ONLY" but when I took off the lines no air or anything came out.
Old May 15, 2011
lazlong's Avatar
I can't believe it's running that bad without throwing a code. Take it down to Autozone and have them scan it for codes (it's free). Post back any codes. Just because the MIL isn't on doesn't mean it doesn't have a code.
Old May 15, 2011
floyd107's Avatar
i have my own obd umm i did get three codes the other day.p0113(intake air temp circuit high temp) p0128(coolent temp below thermostate)p1457(manu specific dtc) but they just poped up recently and i have had the prob for a while. im not 100% sure wht all those mean but i do have a small crack in my exh mani so i figured that was p1457 and the other 2 idk WTF.
Old May 15, 2011
lazlong's Avatar
Does it have live data stream?
For P0128 the service manual says to diagnose P0113 first. P0113 (IAT) can make your car run rough like that.
To test the IAT:
1. With the key ON, engine off does the IAT read 5V?
YES- step 2
NO- Check for bad wires and loose connections at the IAT sensor and ECM/PCM.
2. Turn ign to OFF
3. Disconnect IAT sensor and jump the 2 terminals on the wire side of the connector with a jumper wire.
4. Turn ign to ON
Still getting 5V?
YES- step 5
NO- replace the sensor.
If you need to go further just tell me.
P1457: EVAP Control System Leakage (This can also cause the car to run rough)
There are 6 pages of diagnostics on this. No way man, I don't have the patience or finger strength for that much typing. For more on that and all this: https://www.civicforums.com/forums/1...e-updated.html
With all these codes it could be a bad ECM/PCM but not likely at this point. All those ground at G101 ( runs from the engine to the radiator support) so, check to make sure that ground is good also.
Old May 15, 2011
floyd107's Avatar
what do you mean live data stream? on my obd
Old May 16, 2011
lazlong's Avatar
It shows what the sensor is reporting in real time to the ECM/PCM via the DLC (data link connector). It's a feature on the scanner.
Old May 16, 2011
BlueEM2's Avatar
Whachya lookin at?
^Sounds expensive
Old May 16, 2011
lazlong's Avatar
Nah, you can get 'em for less than $100 now. I have this: http://www.mactools.com/Product/tabi...0/Default.aspx
Old May 16, 2011
BlueEM2's Avatar
Whachya lookin at?
Well that's not too bad ... I'm gonna have to look into it.
Old May 16, 2011
lazlong's Avatar
If you do get one, get one that is update-able.
Old May 16, 2011
floyd107's Avatar
well even with the codes i dont think they are telling me whts wrong with my prob idk.maybe a computer prob too and its not picking up the readings. its weird because once in awhile the car will completely stop vibing and run like brand new.sometimes i think the car is not even on thats how smooth it gets.
Old May 17, 2011
lazlong's Avatar
^^ Definitely sounds like a sensor or comp problem.
Old May 24, 2011
floyd107's Avatar
ya idk is there any way to test that? to test if it is my fuel system is it safe to unplug my fuel rails and use starting fluid in my throttle body.
Old May 24, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
It's $64 on Amazon.com, free shipping (super saver, or prime).
http://www.amazon.com/gp/product/B00...A1C2436WDJ39HA
Mac Tools rebrands Launch CReader products.
Craftsman rebrands Innova CanOBD2 products.
Old Jun 5, 2011
floyd107's Avatar
is that safe? and would that do anything
Old Jun 5, 2011
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
If its used right its fine it is safe. IF you had full out ether and used it wrong possibly. Commercial starting fluid is a pretty low percentage of ether. Ours is 80%. I am a John Deere mechanic. You can break rings and such with ether on some diesels, but they are twice the compression of our engines. Ether doesn't compress like O2 does....
Old Jun 6, 2011
floyd107's Avatar
thanks and what about the fuel rails is it ok to run the car with them unplugged or will that damage anything.(computer,rings,etc). if i unplug them will i have to do anything to have the car run back to normal( restart anything)
