p1129: map higher than expected.
Old Jun 21, 2018
  #31
HonduhDad's Avatar
HonduhDad is an unknown quantity at this point
Thumbs up Re: p1129: map higher than expected.
Thank you SOOOO MUCH for this post. I spent a week trying to figure out what was causing my son's 2003 Civic 5 speed to stall when warm, and lose power on the highway around 3500-4000 rpm. It would run fine when cold, but when warmed up would stall when you took it out of gear. Fortunately, I didn't start changing out all the sensors (only one O2 sensor which needed changed anyway). I had several people giving advice and telling me it couldn't be that the timing belt moved (including myself ).
My camshaft had advanced two teeth - I know, how does the camshaft move forward two teeth when it is driven by the crank pulley. But that's what happened. I KNOW it was put on correctly initially, but somehow something happened to make the cam advance.
If you are having the issues described above, do yourself a favor, and before you change out the MAP sensor, both O2 sensors, the IAC valve and countless other items, check your timing. It's weird, but once it's fixed it runs great!
Thanks again for sharing!
KDELUCA
Feb 18, 2023 07:43 AM
2kej6
25
Aug 16, 2019 10:56 AM
Klaula86
Oct 24, 2017 07:02 AM
dcneo
Feb 1, 2010 10:40 PM
blckpwdr
Dec 1, 2003 09:52 AM
