Help a new Honda Owner with Headlight Problem
Old Mar 13, 2011
X02's Avatar
X02
Gas Sipper
X02 is an unknown quantity at this point
I just bought a used 02 Civic Ex. I do not know the brand of head light installed, but they are projector/halo headlights. Heres my question. THe passenger side lights up fine. The driver side is very very dim. I tried changing out the bulb and its still dim. Both lights are dim.. the low beam light is basically non existent. Turning signal works fine and all surrounding lights are good. I checked for thrown codes and came up with P01298 code. I did a little research on this code, being a voltage issue. Is this a cause of the dim light? Could it be a sensor chip? I want to make sure, before going back to stock replacement headlights, if i can solve this issue.
Thanks.
Old Mar 13, 2011
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
Re: Help a new Honda Owner with Headlight Problem
probably a ground problem. Check to the wiring to see if the harness is compromised, as in stripped.
Old Mar 13, 2011
X02's Avatar
X02
Gas Sipper
should i check the relay box? these aftermarket lights have to have a relay box correct?
Old Mar 14, 2011
mkymonkey's Avatar
there shouldn't be one. Typically most aftermarket headlights are plug and play.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
